Tech7
XS650 Junkie
If you check out his video on the opening page, I believe it's a single neon throttle body.
Okay so I'm new to the xs, just got my first one a few weeks ago... But I'm a fabricator by trade so this should be a fun project... Anyways, don't shoot me if this is a bad idea or completely a newb question but could you use a fuel injection system from another 2cyl bike or even a Yamaha raptor cause I believe the 700 is FI and close to the same CC's.... Idk if that's a possibility or not?
1. will the throttle bodies mount up to the XS parrallel twin arrangement?
2. are the throttle bodies the right size for the 650cc displacement?
I would think you'd use a single throttle body.
I have done alot of fi and the only real sensors you need to make it work are
map manifold air pressure
iat inlet air temp
water temp in this case oil temp for cold start up
crank position sensor
throttle position sensor
o2 sensor
From what I see it would be very easy to do a two into one intake with a single tb. This will give you spots for the tbs and iat sensors. The oil temp would be in the case and the o2 sensor in the exhaust( would be better with a two into one). The only one Im not sure about is the crank position. You would have to mount a reluctor ring on it with a mag pick up for timming. just my 2cents
Why? The systems on newer bikes he want's to port over use a TB per cylinder. To use a single means larger TB and expensive 1 into 2 manifold.
-PO
I've got the whole bike apart right now doing the finish welding on the frame. One less thing I have to do later. Next up will be mounting points for the gas tank, fuel pump, regulator, megasquirt, coil, electrical stuff, mount the tail, build the sheetmetal around the tail, finish the swingarm, ect..... It seems to go on and on. But I've been able to order a few parts lately and that always makes me happy. Got some tires finally, new front fender, handlebar switches, rear seat. Hopefully a few more items soon.
Hugh, you took that on for a customer, or for yourself? If a customer, then you're crazy!![]()
Is that MRD system a mechanical system? If I remember right they have a crank driven fuel pump. You will have to adjust it way down since you are adapting it to a 4 stroke. I might be wrong too. 2 strokes and I never really got along.
Big money in EFI. I have $600 in parts and I'm still missing the $400 Microsquirt. Once I have it though I'll be ready for a build thread.
Can I borrow some time from someone, I've ran out!
