PAPAFOXTROT
I have a 81 XS650H with the Regulator/Rectifier all in one. I have had charging problems ever since I bought it. Motor runs great but leaks some oil out of the clutch push rod seal (have a new one to replace). I have not thoroughly checked the grounded wires but my rotor is fine reading at 5 Ohms between rings which means rotor is good. Brushes are also good length.
My head light never worked but when I bypass the regulator w/ a jump from the green wire to ground, it works. As I rev the engine up to 3000rpm the voltage at the battery terminals jumps to around 14.5V. Last summer I would ride it around and it died on me 6 miles from home so I let it sit, cool down and unplugged the brake light to get home.
I am looking to ride the XS from one location to my garage to work on it (roughly 20 miles). I will make sure all my connections are clean and mated with some dielectric grease as well as checking all grounds.
My question is can I ride it with the reg/rec bypass with the green wire grounded without doing detrimental damage to the battery/charging system?
I plan on using a battery from my 95 FZR600R to bring with me in case the XS battery dies on the way. I also plan on removing the 81 xs650 reg/rec and installing the Chrysler Regulator and Radio Shack bridge rectifiers like many have done.
Thanks,
Paul
Thanks,
Paul
