MFJustin
Welcome to Thunderdome
Picked up a set of 7/8" grips from monster craftsmen. The typical set that most other online retailers carry. Left side grip and right side throttle and grip. The left side grip slid on easy enough with some hairspray which will dry and make it stick.
My question though is in regards to the right side grip/throttle assembly. Of course it's supposed to rotate so I put nothing on it but some grease to help it slip on easier. I've got a set of ape hangers from TC Bros that these are going on. The grip/assembly will slide on the bar but will drag and will not rotate smoothly like a throttle is supposed to do. I tried this assembly out on my spare set of drag bars and it functions exactly like its supposed to. Anybody else have something similar like this happen, a throttle assembly that doesn't rotate smoothly on a new set of bars. I'm thinking maybe I should sand down the bars some and see if it works smoother but I'm not entirely sure if that's what's causing the problem.
