bassgoat1979
I have been going through hell with points ignition on a VF500 stator-Banshee mag setup. With a accel cap. It is running excellent from idle to WOT and I know the carbs are perfect. I have straight pipes and pod filters. Went 1 up on the pilot and 1 on the main. I know it's ignition though. I have to set the points to about .020 to even get it start. It runs bad like that over idle, but I have to idle it to about 1400 rpm to keep it idleing. If I pop the throttle though it takes off on it's own and I have to idle it down to bring it back, then it stalls. hooked a battery up and it will run with normal .016 point gap and not stall at 1200 rpm even with the headlight on. So it seems that the point draw a LOT of power.
Do I have to go with a electronic ignition? Am I just beating a dead horse here? They must draw less energy to spark. When I look at a Banshee with a little 75watt stator you can start that and idle with head lights on. Even a very low idle with light almost off from the lack of power. Still won't stall!!! There is no way this will and the stator is much bigger. It has to be the CDI sytem right?
The only thing is I'm scared to run the Pamco ignition with the magneto setup because I know this burns up LED lights at low speed flicker. Has anybody ran the Pamco with a magneto for a extended period?
