SDcaffinatedXS
- Messages
- 36
- Reaction score
- 0
- Points
- 6
Hey guys i have a 1980 xs650 and im having trouble getting her to run. So heres the scoop, the bike has bs34's with heiden tuning needle jet kit with setup to run a free flowing exhaust so the jets that came with it i installed along with the needle installed on the 3rd notch down. Carbs are running xsperformance pod filters. Coil is high output from mikesxs with ngk caps and iridium plugs gapped alittle less than .040. Battery is agm 12v 8amp hour. Carbs set about 4 turns out and exhaust is basically strait pipe. First of all im getting a good spark from the plugs and both are firing at the same time. When i kick start it, it seems like it wants to start but it doesnt want to run. Ill get an occasional poping and a few times it puffed some white smoke and came out from the carbs. I check the plugs theres a little bit of black stuff on it, and since its popping it makes me think its running lean. This is my first build and im almost there, i just want to get her startef so and help or advice will be appreciated. Thanks.
