Milk_Jesus
I cannot get the nut holding the alternator on to come off (I'm trying to do a pma swap). I have vice grips and pliers at the moment, and that fucker won't come off. Any tips?
I used a three claw puller. Worked like a charm.
If you are stripping it out, your using it wrong. If you just tighten the bolt down to get it off, that's wrong. This will as you found out just strip the threads.
You spin the outside all the way on. Screw the bolt down till good and snug. Then hit straight on the end of the bolt.
If it don't pop right off snug the bolt down and hit the bolt again.
The tension of the bolt pulls on the rotor. The strike of the hammer pushes the end of the crank. This pops the rotor off.
Soaking it penetrating liquid for a day or two helps.
Using a three jaw puller, if not used right will pull just the inside part of the rotor off. This pretty much ruins them. If you are pulling it to get it rewound, be very care full. If pulling to replace with a PMA, again be careful. If you can get it off in one piece, rewinders buy them. The early points rotors are not worth as much but the later TCI rotors are worth more.
Here's the project. It's close, finishing this charging system then on to the ignition and then it's just to wiring. For anyone that was curious haha
Don't feel too bad about hurting the tool. I've know many "mechanics" who don't understand tools as a well as they should. Knew one that didn't believe in using a torque wrench.
Hell yeah that looks good!
Are those 7/8" bars? If so, more info, please.
Is that a drag specialties seat?
