I recently installed a pamco ignition system as well as a green moster coil. I am running a banshee alt set up as well as dellorto carbs from Mikes. I also have mikesxs cam and a 750 big bore kit.
The bike was running and timed perfectly with the points on it and it was running perfectly.
Now after installing the Pamco ignition system, green moster coil, and new advance unit springs the bike has a super bad idle and does not rev when twisting the throtle.
With the bike on the center stand in neutral will either doone of two things when kicked over and finally started.
1
It will have a high and rough idle. When i check the timing marks with a timing light the mark is all the way over to full advance. It also sounds like one of the cylinders is missfireing at this high idle every second consistantly.
when i attempt to twist the throttle to bring the rpm up it bogs down and and it sounds like it miss fires on at least one of the cylinders.
OR
2
The bike will start up with the throtle twisted at about 1/4 -3/4 and will sound normal. Im able to rev it and have it sound like it always does (vroom vroom type of sound). As soon as let the rpm's settle back down to idle the motor will die.
I check the timing marks while doing this and it looks to be at full advance
Im stumbed as to what he problem maybe because the bike was running perfectly before
Could it be the advance springs being too weak? I thought it might be this so i held the advance weights closed and tried starting her up again and came accross the same problems.
any ideas as to what it could be? Im half tempted to throw the points stuff back on blaaaah.
1
OR
2
