gearhead13
I can't seem to get it right. I adjust the right hand side first at the widest point on the cam to .012,but when I put a light tester across the points to adjust the points plate after I have the right side on the compression stroke and rotate the plate couterclockwise so the light will turn off it never does. I put new points, ignition coils, plug wires, spark plugs, condensers,ignition switch. I'm running basic wiring no kill switch or anything just ignition switch to turn it on and off for now just so it can start. I have each yellow wire from the coil to one of the points and condenser and both black wires from each coil tied together and going to the ignition side of the ignition switch and the battery side of the ignition switch going to the red wire on the regulator. Thanks in advance.
