Dumbmonkey
Hi there!
I'm having an issue trying to resolve what keeps blowing my signal fuse. I realize that I'm going to have to go through everything with a multi, and any advice on that would be welcome, but first I thought I'd see if anyone might have any insights.
I have a 1981 Special 2 that is pretty much stock. I changed out the directionals with K&S turn signals, and replaced the stock flasher with a 552. The signal fuse started blowing last week and I had attributed it to the old original fuse box as one of the clips broke when I replace the fuse. I've installed an inline ATM fuse block and the fuse still blows. I thought it might have been the turn signal switch as that had given me problems in the past, but after disconnecting the entire pod, the problem persists. I've gone to disconnecting everything but the main switch in the headlight bucket, and all 4 directionals, and the fuse still blows.
Does anyone have any ideas of where else I might want to be looking for the source of this problem?
