xs650newb
So I am taking the head, rockerbox, and jugs to a machine shop soon for a port/polish and bead blasting to clean everything up. The cylinder sleeves have some rust in them so most likely I will need to go up a size or two on the pistons.
What is the process here? Do I tell the guy the sizes of various pistons and he finds the smallest piston that will fit in the bored out sleeves? Does he bore out the sleeve before I give him the pistons, or does he need the pistons to properly bore the cylinder? Do large piston sizes mean more engine power because the displacement is larger?
Also, I am debating doing the port/polish myself with a dremel. My understanding is that you simply remove casting flaws, smooth the exhaust, and roughen up slightly the intake. I have 2 heads so if I mess one up, its not a game ender. Any thoughts?
Thanks,
Adam
Thanks,
Adam
