BarrieC
Hi Guys,
as you know got an XS650 SE (basket Case). engine is now rebuilt ready to be fitted in the frame, Carbs all fully rebuilt and ready to go.
Ignition with the bike is standard TDI.
I wanted to bench test the ignition connecting the pickups, TDI box and connecting in a battery, with a multimeter connected between the orange Neutral to Coil TDI box outlet and the Neutral from the battery.
I was expecting to see continuity (zero resistance) with the battery connected and then disconnection when I passed a small magnet across the pick-ups. I was originally showing no connectivity and then fluctuation after the a minute or so and occasionally impacted by the magnet passing - in summary not a positive result:
1. I'm getting the correct resistance across bot pick-up coils
2. All connections are visible (bench connected)
3. Battery voltage good
4. Taken into account that connectivity goes into sleep mode if no magnet activation
As i've just rebuilt the motor, I dont want to be messing around turning over the engine, without firing it, as this will be before proper lubrication will have taken place.
I do have full points set up, in my spares (Just in case I put Bearings in my 82 Camshaft), I will need a Condenser pack, but thats quite cheap.
But I only have the single coil for the TDI ignition, can I use this and just connect both the points Neutral connection to the single coil Neutral connection, basically giving it a wasted spark.
This would allow me to get the engine running and lubricated, so I can play with the ignition later - I have Gonzo GN250 TDI box on order
Thanks guys
Thanks guys
