glennpd
4 bikes, 4 dogs, 1 wife
If you are like me, you probably do not look forward to removing and replacing the carb set on your later model XS650 with co-joined bodies. Sure if you remove the cam chain adjuster crown nut, and remove the carburetor joints (manifolds) the job is a treat. But removing the joints can be a problem as well if you do not have the properly shaped and sized tools for the task. However it seems that if the gasket between the joint and cylinder head were eliminated the extra clearance would make the R/R carburetor job much easier.
I noticed that on my Virago there is no gasket between the joint and head. Instead Yamaha used an o-ring to seal the faces.
Has anyone modified the XS650 carburetor joints to accept an o-ring? I would think that with the proper machining tools it would be pretty easy. Yes, I know that it is always easier for the person who has never done it, but I'm just sayin' ...
Glenn
Glenn
