xs650brat
Looks like the PO of my '78 XS650 Special broke (or cut?) the tacho housing (pictured below as #1 in the diagram). There's no tacho on my bike and I don't plan to add one, but the o-ring #2 is leaking so this needs addressing. I have parts on the way (replacement housing, threaded insert, o-ring) along with Mikes XS screw-on tacho cap to cap off the tacho housing.
I'm looking for insights and ideas as to how to get the remaining lower portion of the broken housing out of the crank case. I believe that removal of the housing can usually be be done without draining the oil or removing the crank case as long as you maintain downward pressure on the tacho drive gear #7 (so that the washer #8 at the base of it doesn't come loose and wander around in my crank case!), but have a couple of questions before I get at it:
Insights appreciated!
- Once the bolt #5 that retains the housing in the crank case is removed, how would you get the remains of the broken housing out? The highest point of the broken housing is inset within the crank case, leaving nothing to grab. Pick through the bolt hole and lift it up? Pick between the o-ring and the housing and pull it up? Any ideas or insights?
- How tricky will it be to replace the housing while maintaining downward pressure on the tacho drive gear so as to not lose the washer at its base? Are we talking high risk, 'diffusing a bomb' levels of careful, or probably okay as long as I'm careful?
