Here was my solution (?) today.
what I started with:
don't want any shavings in my valves do I:
hi-tech depth measuring tool:
first tool from a helicoil set, drill bit with tape depth guide, use spray grease as lube:
tap from helicoil kit, use tap fluid as well:
pushing in the helicoil insert:
original bolt back in:
looks good:
Had a bit of an issue though. Basically for anyone else that needs to do this - it is very easy if you get a helicoil kit and go real slow, using tap fluid and some other lubricant with the drilling. But and this is a big But - make sure you get a secondary tap and use this after the first tap that comes with the kit. The second tap has thread cutting all the way to the tip whereas the starter tap has a smooth taper to get it started. What this means with a blind tap (tapping where you are not going all the way thru the material) is that you can't cut thread all the way to the back of the hole with just the first tap. Of course I only realised this too late.
In practise today this meant that my helicoil insert wouldn't go all the way in. I then cut the bit that was jutting off and thought it would be ok. I then screwed in the original bolt which seemed to get very tight. I think this is because the helicoil gets tapered towards the back as there isn't any thread cut at the back. I wanted to pull it out and use a secondary tap but it was stuck very firm and so I just carefull screwed it in a couple of ml and it was done.
However now I'm stressed that over time it may cause a crack as the bolt is compressing against the steel helicoil in a slightly underdone hole in an aluminium head. eek. seems ok but I'm trying to care for this old girl, not cause other issues. thoughts?
