Scrambled
Motorcycle Man
Question .... Do you need a " T" on a set of BS 38s ? I don't have one , I got stock petcocks and the vacum lines that go from the tank to the barbs on the boots . Seems to work good .
most of the time 3 wraps of good natural gas Teflon tape works,,, but this set up he sells is the worst bull s h i it i have ever seen for a fuel tee,,, why not just a simple oring groove,,, da mn man
meet the new boss, same as the old boss
why is this not adressed ,, would you ride a bike on you bulll sh i t
i have already had issues with this mfr
this all have leaked, failed , fucking miserably fuel tee i the uppity of of god damn ignorance ... i have at least 3 in my postulation mikxse mail me rick690@msn.com
don't even defend this fuck
i will 3l hand you that ass
what kind of set up is that,,, dumb fuck....... don't t play with me ,,,,,,, i know better
you want ride on that dumb shit
i got news for you sunshine,,, pink is not well he is back at the hotel bitch
mikexs is a fing joke in more ways than 20
why does he continue to sell these,,,, why not just have an oring groove... i am fighting one now that is pure junk
http://s591.beta.photobucket.com/user/wildmanv65/library/1%202011%20xs1100/mikesxs? the junk tee is on top the xs850 in the bottom one
I know that , the question was about the "T" between the carbs . My bike didn't have one and seems to work fine without one . What does that "T" do ? I have seen people put a fuel filter between the carbs , but I never thought that it would do much good there .All BS38's carbs come off bikes that had twin petcocks in their tanks from 70 -79
On the BS38s, all you need, and all there ever was, was a crossover tube connecting the two bodies. No tee.Do you need a "T" there or can you just have a line connecting the two carbs like I have ?
Thanks. Does the "T" if you use one, need to be between the carbs ( Like I have seen ) or can you put it anywhere on the fuel line before the carbs ?On the BS38s, all you need, and all there ever was, was a crossover tube connecting the two bodies. No tee.
The crossover tube connects the fuel supply to the carbs, so you only really need one inlet. You can plug the other inlet, and then you only need one petcock. The petcocks eventually leak, doing this halves your petcock problems and hassles and simplifies everything, and now you only need one filter. I do this on all of my BS38s. The single supply line provides plenty of fuel, look at how small the jet openings are and see for yourself. You don't even have to remove the unused petcock, just plug it, now you have a spare for when the other one starts leaking.
I know that , ...........the question was about the "T" between the carbs . My bike didn't have one and seems to work fine without one . What does that "T" do ? I have seen people put a fuel filter between the carbs , but I never thought that it would do much good there .
The "T" that MikesXS supplies depends on being pressed together to keep from leaking. The best way to do that is to use a bar clamp to press the carbs together with all of the mounting screws loose. Then, you tighten all the screws on the bottom angle and top butterfly plate with the clamp still applying pressure to keep it from leaking. You can't do it by just applying hand pressure to press the carbs together:
