Rd51
Plastic straw? Eeooww! Double check the screw pitch, isn't it 5mm x 0.5 ? This tap is available, but may not solve this problem if the aluminum threads are severely stripped, and if not run precisely over the old threads, may strip it even more. If the aluminum threads are still halfway there, new mix screws may have enough external diameter to sufficiently grab.
This would be a good project for a budding lathe student. Make replacement screws with a slightly larger (.005") diameter, same pitch.
Caswell offers an electroless nickle-plating kit, easy to do at home, could add .001" to .002" plating to the threads to improve purchase (thread engagement).
The mix screws handle a fuel/air mix, they aren't air screws.
Right when I thought this was an easy fix!
Thank you for all the info.
Yes the tap is 5mm by .05 pitch, I found a site online that carries every tap known to mankind. I have yet to pull the old mixture screw that is being held with a straw, so I'm not sure at the moment how bad the threads are in the housing.
I'll be sure to be extremely careful while threading in the tap. I figure I might as well try a tap first, and if no luck I will proceed with your other recommendations.
I understand it technically isn't a screw. It sounds like you're saying the mixture screw controls both fuel and air simultaneously? I was always under the impression that if it's fuel screw, any adjustments made would only affect fuel flow (I.e. Turn the screw in, less fuel, leaner. Turn the screw out, more fuel, richer) And conversely if it's an air screw (turning in richer. Turning out- leaner)
^if that is the case I was asking if it is the latter of the two, is it that crucial the threads are perfect? Will the threads be responsible for sealing as well? Or does the o-ring take care of the sealing, and the threads are just responsible for adjusting the screw?
Hopefully I made some sense in what I'm trying to ask. Thank you again!
