Happy Friday! Finally home enjoying some ice cold Stone IPA's after another week. Looks like I'll be working tomorrow as well. Gotta love overtime.
Anyways, this is the progress I made since the last post.
Dove into the clutch; was happy to see the clutch hub and boss are still in great shape. Those screws were in there super tight. Took a little bit of force even with my impact driver.
Pulled the starter. I was expecting the gears to be all chewed up from the way the starter sounded when I tried using it. Almost tempted to repair the "drag clip/spring" (can't remember the technical name) and run the starter...
Removed the tach drive since I will only be running a speedo.
I began cleaning and prepping the jugs and cylinder head. I've been reading a lot about this subject (painting/powder coating them vs. heat retention) And I've decided that I will not powder coat them. However, I plan on painting the jugs, clutch cover, ignition cover, and valve tappet covers matte black, and leaving the cylinder head bare.
I've noticed in some of Hugh's videos on youtube that his customers engines are powder coated. Now, I do not know Hugh on a personal level, but I can tell he takes pride in his work. This leads me to believe that he would not have an engine powder coated if he felt that the engine would seize soon after leaving his shop.
I could be totally wrong. But that is my justification. I've decided to paint instead of powder coat, so I can personally manage the thickness of coats being applied. I have faith in my prep work that the paint will hold up. Time will tell.
Removed the valves from the head. Began cleaning the gasket surfaces. "Yo" from Contemporary Auto in Huntington beach will be preforming the valve job, as well as checking the piston/jug clearance. We use him for all of our diesel rebuilds. Extremely knowledgeable, and very easy to get along with. I would trust him with my life when it comes to this line of work.
And finally; I posted earlier that I purchased some K & N pods. As twomanyxsb1's pointed out, I should've researched before I purchased. However, I assumed (you know what they say about assuming) that K & N is one of the leaders when it comes to intake systems, and that purchasing their product would mean that I'm getting top quality. But, I understand now they do not function well with these CV carbs.
When it comes to the bike running right, I do not want to chose form over function. But before I give up on these filters, I thought I'd ask a couple questions. I've seen some pictures of other K & N's with a restricting inner lip. I took a look at mine, and I'm not seeing this same lip? I'm aware that even though the lip might not be there, there are other issues (turbulence, etc) that may be a problem. Thought I'd ask.
Have a great weekend everyone!
