Ok, so earlier this year I finally finished my build. Its a stock internals 80' that I added the following to- HHB PMA, PAMCO and new VM34's from Hoos racing. Bike was running great and I had a few fun rides on it. Since I didn't touch any of the internals it had a generous oil leak, that kept getting worse(go figure). So i bought a gasket kit, took the motor out and replaced the offending gaskets, mainly the jug to case gasket, although the head gasket was leaking as well. After this, I reassembled and went for a ride, bike was soft down low, then would pull like a bat outta hell. After some research on here, I determined the cam was slightly retarded. Took it apart again, reassembled(possibly hastily), then would try and brake your ankle while kicking. Too far advanced. Again w/ the diss-reassemble. Now, it will start first kick, barely run and won't take any throttle. I have messed w/ the timing to no avail. I did make sure that I was at TDC and the cam lined up perfectly. The notch was straight up, and the dimple was perfectly level w/ head. I used a dial indicator and a timing wheel. Before I rip this thing apart again, just looking to see if there was something i missed. Thanks in advance for any help
