Thanks for the reply's fellas, I cant tell you all how much I appreciate it!! So I went ahead and replaced both of the plugs just hoping that maybe I had a bad plug and was causing it not to fire on the left side.That didnt help and now Im afraid to ride it if its only hitting on one cylinder and popping loudly out of the left pipe. But when I looked the old plugs that I took out the left was dirty and little oily and the right was a nice tan color! So that would lead me to believe its running lean? Im going to do a compression check tonite just to rule out a bad valve, and then I feel I should re jet the carbs due to pod filters, and great scott pipes. And Kent in KC, thanks for mentioning that, When I installed my pipes I got from Mr Scott I never put my stock gaskets on those pipes so they are currently without them but I know they are both tightened down evenly, but will check again tonite when I run a compression check! I will keep you guys posted on this issue! My bike is so close to Rock N Rollin I just need to get this resolved quick! After all, riding time is fading fast in my neck of the woods!!!........Oh ya, also forgot to mention the popping mainly starts up when its idling and you give it gas, and at random while riding, which my buddy thought that since it's missing so bad that's why its popping when its trying to hit on that left side??
P.S. Sorry for the double post, Couldnt figure out to delete one!!
Thanks Again.
