Just a little update. Got the POR 15 today and have the tank off. Discovered that the petcocks leak a little where the seal is. When I got the petcocks off there was gunk on them as well. Going to try just cleaning them up before I get petcock rebuild kits.
Good - and when using the POR15 - be sure to keep it
OFF anything you care about. That stuff sticks like sh!t to a hairy blanket and it will wreck paint.
I found that the toughest part of using it is sealing the petcock holes and the fuel filler hole. I used a big cork from a wine-making store for the fuel filler and I made a couple of blanking plates out of old hotel door entry cards for the petcock holes. I just used some duct tape as a "gasket" and drilled holes in 2 layers of hotel "credit" cards and used the petcock screws to hold them on. It worked fine and protected the screw holes from the chemicals.
Tape -
of any kind - is a total waste of time. Despite what they say in the on-line videos. there is just too much water and other chemicals sloshing around during the process - and the tape simply died.
The other challenge with POR15 is keeping the tank moving long enough to distribute it evenly all over the inside of the tank while it begins to cure. I found that I had to keep it moving for AT LEAST 2-3 hours and I gotta tell you, it was exhausting. I finally sat on a stool at my workbench and rested my elbows on the bench while slowly rolling the tank over and over and over.....
Finally, I found the sealer stuff to be a bugger to get OUT of the tank. There is always a little bit left over and you don't want a big lump left in there to harden. I fiddled around for about an hour or more trying to get the last tablespoon of stuff out through the fuel filler hole - and finally, my arms were dying, so I hung the tank upside down (filler hole
down) and rear end of the tank
up in the air so that any residual POR15 sealer would harden right up front in the tank (
just ahead of the fuel filler hole) and up high and as far away from the petcocks as possible.
However, it is
WORTH IT - because the inside of the tank is A-1 and that stuff is tough as nails.
Cheers,
Pete
