xs650newb
Hello,
With the engine at an idle up to approximatley 25% throttle the tachometer is completely unresponsive.
Once I get above 25% the tach will finally kick in.
I figure there are two likely causes
1) bad oil pump
2) something causing friction in tachometer
To check the oil pump I have heard to open a tappet cover and see if oil sprays out. Should I open intake or exhaust? Should oil spray out at idle, or do I need to rev it a bit?
If the tachometer is gummed up I was thinking about some teflon spray. Thoughts?
Thanks,
Adam
1) bad oil pump
Thanks,
Adam
