So I fixed the carb and rechecked the valve clearance. It is a little different, 2 right exhaust valves are a little too large, should have 285 but I have 280. One intake first valve is too small, I have 265, it should be 260 now. Not a big deal. I will correct it.
But that should not be a cause of the oil in all 3 carbs. They all have an equal amount of oil. See the screenshot of the manifold.
I checked the valve head oil drains and crankcase breather. From what I understand how air circulates inside the engine it is impossible that I have an air pressure problem there.
After fixing and cleaning the carbs again, the engine starts and runs without the choke now. I kind of balanced the carbs to the point that the balance tool shows all 3 equal scales. I don't think I solved the mixture yet, probably due to the air pods.
The oil can get only from the head down or from the bottom of the cylinders. I checked the cylinders through the sparks holes, they are all wet.
So the question is:
1. do I have a problem with piston rings? - even though I installed new ones ( standard ) - need to mention one more time, that the pressure is 170 psi on all 3 cylinders on a cold engine. So it is good I think.
2. Do I have a valve issue somehow? - seals have been replaced as well and valves refurbished using the valve cleaning paste.
3. Valve guides?
I don't understand why all 3 have the same issue. If only one would be bad, I could imagine some failure somewhere, but all 3 are identical.
I scratch my head here. I could remove the valve and cylinder head to see how it all looks like there, but before I do that I need somebody to help me out and confirm that, yes that makes sense to do it next.
Thanks, guys, stay with me, please.
XS750F 1979
