sgallaty
Antihero
So I think I have an understanding of this but I want to lay it out and talk about it to make sure I've got it -
I'm scavenging an engine from several other engines - top end from one, jugs from another, crankcase from a third, odd bits from all over.
one question I have is about fitting the pistons -
My understanding is that the pistons are marked with a number that represents their size - without the "74" prepending it. So, we will have (74).093.
Jugs are printed with a blued number on the outside of the jug which represents the bore size over 75... so that number is (75).xxx
All of the jugs I have are marked "010"
My understanding is that The clearance between pistons and jugs should be .050 at the min piston dia - max jug internal diameter.
So clearance = (75).<jug printed number> - <74>.(piston printed number).
My questions then are :
1) Do I have this right?
2) So long as they are in tolerance, does it matter if my pistons are the same dia. (and assuming I use the right pistons for the right rods etc.)
3) what gotchas do I look out for? I already understand to keep the valve cover with the head, and the pin with the piston. anything else?
4) any parts I should always replace? Rings? piston pin clips?
thanks in advance
thanks in advance
