ckdaly9
Long time lurker, first time poster,
I've built quite a few of these things and never encountered the issue i'm about to describe. I have scoured this site and the internet to find a similar issue with no luck.
So 83 XS650, Mikuni VM34's, Pamco, Hughs PMA. Other than that stock.
Bike was running awesome, but the stock charging system was junk so I installed Hughs PMA kit. After installing the kit, Bike was running great, in time and pulling hard. Then boom. junk. nothing. misfires and stranded.
Turns out the brand new gel battery shorted out (couldn't handle the pma..I dunno..) I didn't suspect that the new battery was the problem, so I checked everything else. Valves, Cam Chain tension, Timing, Compression, Float levels etc.. Installed a new Yusa Battery and fired it off.
Instantly it foulded the plugs. covered in gas and oil Fuel is puddling up in the manifolds, so I figured maybe my floats were a bit to high. I re-adjusted those, no change. it doesn't matter where I set the floats, same issues. I know the pamco is a bit off, but I cant time it with the gas/oil covered plugs, and i'm surly sick of blowing money on sparkplugs troubleshooting this thing!
I'm at my wits end. Hopefully some of you dudes can give a fella a hand!
Specs are;
Compression 130-135 even both sides
TDC Set, and in time (except for adjusting pamco unit)
Valves set to manual spec
Cam Chain set to manual spec
Mikuni VM34's
Main; 190
Pilot; 25
Needle; 6F9
Clip is in the 3rd position down (towards the carb body)
Thanks in advance for any help!!!!!
-chad
Specs are;
Mikuni VM34's
Main; 190
Pilot; 25
Needle; 6F9
-chad
