My 1977 xs360 hasn't been wanting to rev past 7-8000 rpm without sputtering out, you can hear the left cylinder start to crap out. I tracked the issue down to that side flooding with gas, but only at wide open. I ran it around just cruising, pulled the plugs and they both look healthy. A couple minutes of trying to rev it up high and the left plug goes black. I can even pull back the air filter boot and see the carb spitting out fuel when I rev it. I can also shut off fuel flow and it'll start to rev up like normal.
I've been through the carbs numerous times, haven't found any clogged ports, ripped rubbers, anything. I did replace the needles and seats and confirmed the floats are air tight. Floats are set to 26mm off the base. Checked timing, recently replaced coils, carb holders, set valves, fixed a low voltage issue, replaced plugs. Nothing changed the issue. I haven't checked compression, but it feels strong with my finger over the plug hole. And reaching over the carb while revving, it starts to suck my hand forward.
For the life of me I can't figure it out. I can only think to lower the float height a bunch, but if it's in spec I can't see how it would be the issue. And everything on the bike is pretty much stock by the way.
