Frojku
Hi, I'm from Eu and new there. Sorry for my English. I modified a Yamaha xs650 1981 3L1. Stock jets, mixture screw 3 turns out. Compression is good. Run open exhaust with silencers inside and pod filters on carbs. After changing to new boots there appears a new problem. Left exhaust produce normal hot air, right is cold but works. Again I took carbs out for cleaning, adjusted the float level and also re-torque head base. After those steps the problem is still there but conversely - right is hot now, left is cold. Can I ask what should I try now? Try to set timing maybe?
