TeeCat
One-Mik Wonder
Greets, all...
I'm mounting and hooking up a new Mike's tail/brake light on my experimentally bobbed fender after having been hit in the rear two weeks ago. I have sorted out the mounting issues, but have a wiring question.
My '73 harness uses three wires, as did the last light I had from Mike's, which was too damaged to re-use. The new light, however, only has two wires. I suspect that one is tail light and one is brake. My question is whether one of these wires also serves as a ground, and how would they connect to the existing wires from the harness, or whether I need to add a ground.
If I do need to add one, there is a bit of an issue because the body of the light is alloy. The bolts that actually affix the light itself to the are steel, but the threads are so close to the inside body of the light housing that I can't get a nut on it to affix a loop or horseshoe terminal. Any other ideas for attaching a ground to a bolt's threaded end... some kind of clip, perhaps, that I could crimp to the light end of the ground?
If I don't need to add a ground it will be a non-issue, but I suspect I will. This light mounts on rubber, so I don't see how it can ground through the light body if it's alloy. Is it conductive for this purpose?
Thanks!
TC
Thanks!
TC
