You'll want to replace the front cam chain guide, the valve guide seals, and probably the cam chain. Anything else like rings, pistons, valves, etc. will have to be decided once you can get a look at them.
Buy the complete engine gasket set. Besides the gaskets, that will give you all the valve guide seals and all the o-rings you need. Also get the brass or copper washers for the 4 outside acorn nuts.
