NorazDad
NorazDad
This is an 81H with the stock Mikunis. PO had installed a clear fuel line with a plastic fuel filter. Due to the crazy configuration of petcock and the position of that dual fuel connection for the carbs, there was a small kink in the line. When I opened the petcock, I always saw gas flow.
I bought and installed a new clear reinforced gas line and glass filter. But when I opened the petcock, no gas would enter the line. Do I need to bleed the line by draining the carbs?
What is going on? Will the carbs and engine start the fuel flow when I try to start the engine? How long will that take? I'd hate to exceed the 45 seconds allowed for the Pamco, EAdv and the high output coil.
Should I just keep cutting back the new line and testing it till the gas flows?
This should have been simple.
Thanks for your help guys.
