Hey guys, new to the forum here but lots of info here....great site!
Anyway, I acquired a 1975 xs650b a few months ago and have been working on it all summer. The guy I received it from had it for 20 years and then let it sit for 6 years. I've finally got it somewhat running but am having a bit of a problem. I can start it almost immediately but it idles rough and sometimes not at all. I can tell the right cylinder is not hitting, I can hold the right side exhaust and can't even touch the left side. When I hit the throttle the right side will start hitting but it is very hit and miss and it pops, crackles, and backfires horribly. I can hold the throttle and it continues to run but the backfires never stop yet the left side purrs like a kitten. I have noticed a black oily deposit on the spark plugs after running for a few minutes like this.
So far I have replaced (with brand new parts) the coils, points, condensers, and plugs. The tank had a ton of rust which I removed and I completely 100% cleaned both petcocks and carbs. I left the carbs at the exact factory settings and they are completely stock. I feel 100% confident that the carbs and fuel are free flowing with nothing plugged up. And I've been through the timing 5 times....checked with an ohm meter and both points just start to open at the F mark.
All four valves seem to be traveling fine with the covers off so I decided to check compression. I was getting a reading of 120 psi on both cylinders but I did however try filling a little 3&1 oil in both cylinders and both cylinders gave me a 150 psi reading.
Any advice?? I have racked my brain on all this. Bad cylinder rings? Fuel mixture to rich on the right side? I am nonstop changing from fuel problems, back to ignition problems, back to engine problems, and all over again.
