What happened when you adjusted your voltage down to 14v? You didn't do it.
If you re-read the first page of this thread, I think you'll see that I tried everything you suggested except for this. I tried to explain (apparently, unsuccessfully) that I didn't see any point in trying to lower the voltage on the old regulator because I had replaced it with a NOS regulator. And since the NOS regulator had no effect on the hot resistor, it didn't make sense to dabble further with the old regulator. Doesn't that make sense?
xjwmx;
I see what you say about the possibility of the current flow through the resistor to a ground within the regulator itself, i.e. contacts fused. But freddy3 said he found no indication of stuck or burnt contacts.
That is exactly right. The contacts were very clean and there were no burn spots. Still, since I had the cover off, I cleaned them anyway, but it made no difference.
He said he measured 15.75 volts, which means the regulator is spending more time with the contacts open causing current flow through the resistor. The contacts move back and forth with current flow making a square wave . If the contacts are open more than closed then the resistor heats up.
That makes sense.
That begs the question, why is the output voltage seen to be as high as 15.75 volts? Well, I think a bad rectifier would cause a high output voltage to be seen. freddy3 did a cleaning job on the rectifier, but it may now have become defective after more than 36 years of faithfull service.
The rectifier I just replaced (with the NOS part) was only ~4 years old. This same thing happened once before and, initially, I thought replacing the rectifier fixed it, which is why I got the NOS part. But when you mentioned the rotor, I also remembered that I'd replaced that as well and that may've been the thing that finally solved the problem. But, honestly, it was so long ago that I don't remember what the final fix was?
So, its likely best to test the rotor, if its bad then replace rotor. If the rotor tests good, then its time to replace the rectifier with a couple of spiffy new bridge rectifiers.
When it comes to changing the oem-style parts, I do get a bit difficult. I really do want to keep the bike stock, including the charging circuit. The only part that isn't oem at this point is that rectifier, which I believe is what caused the problem (and the one 4 years ago) in the first place! A shop I took the bike to for a new battery did something to the original rectifier and it was very shortly after that that I had the hot resistor problem (4 years ago). I'm pretty sure that, over a year or so of washings, that new-style rectifier corrodes/rusts and something inside it shorts out, which causes a chain reaction that results, ultimately, in damaging whatever it is that's causing the regulator resistor to heat up. When it comes to electronics, you guys are a bit ahead of me..
Testing and substitution is the way to find electrical problems. freddy3 is doing a great job by substituting a NOS regulator, and by giving good testing information.
Thanks, I really am trying my best with the knowledge/experience/tools I have.
