SOME SUCCESS!!!!
(With video for your diagnostic pleasure.)
Guys, here's what I did:
I went to get a handful of stock plugs for dialing in. While I was there, I was going to get a compression tester, but they didn't have the rather inexpensive one that I thought would do the job. So that will have to wait. Maybe you can tell me what fittings it will need.
Anyway...
I went out there and set the air screw to three (3) full turns out, with about half or so choke... maybe a little more to start... possibly full. Can't really recall. About 5/32 under the slide. The bike started on the first or second hot kick, even after I had left the choke on all night. Oops...
As soon as it started, the idle speed increased, but got sloppy, and "rich" sounding, so I started to ease it off the choke, but did as joe said and came up gradually on the idle screw. It did respond to that and I was able to keep the bike running with it as I gradually came off the choke. In a minute or so, it was off the choke and idling (slopily) with the idle screw. I used that to maintain idle til it got a bit warmer.
The bike takes throttle at low speed, but idles like a Harley and would smoke a little AFTER I'd crack the throttle, which it normally does not do... or does it very little.
So, I came in to about 2 1/2 turns on the air screw. It seemed to respond to that a bit, but that's about where I left it until I get further guidance from you based on this report and the video.
NOTE: RIGHT after the bike started the first time, there was a little dribble of fuel in the inlet. But I wiped it off, and now there is none, even after several warm re-starts. So it looks less and less like it's flooding, and more and more like its unhappiness with the initial air screw setting, and like a tuning issue. So, I'm encouraged now!
In trying to take a video for you, I had occasion to shut the bike off and restart it three times because I had to run in and out of the house for the camera (I kept messing up the video). The bike restarted first kick, every time, with basically no throttle and no dribbling. As I just put the bike away (rain coming) the inlet is dry.
I don't think the bike ever really came up to temp, because I have not ridden it yet, so any assessment on my part is really not fair, but as it warmed up I had to continue to play with the idle screw, and had to add a little when the idle dropped to around 1000 rpm. But even at that, a 3/16 drill bit fits loosely under the slide. In my (in)experience, that does not really seem like an unreasonable amount of idle screw setting to me; I think that's a pretty small aperture.
It takes throttle well and returns right away, but will bog/hiss under a hard crack, then recover. You'll hear it.
So, I'm encouraged, but a bit stumped as to what's next, so I'm anxious to hear what you have to say at this point. Maybe this will work out! Better day today.
Again: 388.52 feet above sea level, 25 pilot, 200 main, about 2.5 turns out on air screw (I didn't want to go too far in without more input), and maybe about a 3/16 bit loosely under the slide for a lukewarm 1000/1200 rpm idle with no choke.
And weather/time permitting this week, I have to get up the nerve to do my tappets... need to get serious about that if I want a good tune. But I'm a bit reassured now that this was not a huge mistake. Maybe all I need is some patience and a few good heads on this project. I have the second part here.. the first part is the issue for me.
TC
Video:
