http://www.aluminumrepair.com/
I found the above site while Googling to see if aluminum can be soldered. Their product sounds promising, although a bit spendy -- it starts at $65.
What does anyone think? Has anyone tried it?
From the site:
"All you need to repair any metal stronger than new is a heat source (propane or mapp gas), a turbo tip, or oxy-acetylene, and our material. This new repair technology performs well on aluminum, cast aluminum, pot metal, copper, magnesium, and all white or porous metals. You can easily repair corroded or oil-impregnated areas that can be next to impossible to fix using welding machines with aluminum welding rods or other brazing products."
From the site:
