takehikes
Wondering if anyone has a part number for a Napa or auto lite or some other brand of suitable solenoid for our 81? Don’t want to wait to get one from mikes or The like!
Thanks I like that. Also like your fuse box, which one is that?I got one off eBay for like $10
https://www.ebay.com/itm/Starter-So...p2349624.m46890.l6249&mkrid=711-127632-2357-0
That’s this one, it’ll work fine for a chopper but I think you need a 6 position for a stock harness.Thanks I like that. Also like your fuse box, which one is that?
not having an issue other than I threw away nearly all the electrics/wiring on mine as I am chopping it. Only thing Im forced to trust is the TCI, everything else will be all new.You real sure it's the solenoid? I've found a bad one or two but it's pretty rare.
Im chopping so this will be just right. Of course the real trick is trying to hide all this stuff on the TCI models.....That’s this one, it’ll work fine for a chopper but I think you need a 6 position for a stock harness.
https://www.ebay.com/itm/4Way-12V-2...p2349624.m46890.l6249&mkrid=711-127632-2357-0
You can see the (Gonzo) TCI module on the right there inside my "oil tank" I'm running a 3 position w/momentary key switch so no need for a starter button. the only things not in my "oil tank" are the reg/rec witch are mounted on the inside side of my battery box for cooling.Im chopping so this will be just right. Of course the real trick is trying to hide all this stuff on the TCI models.....
True story, they don’t like AC field.gonzo..... at least have one as a spare.
Word to the wise never ever arc weld when the TCI is on the bike. ruining a TCI by doing that is a bit TOO popular.
Nice!You can see the (Gonzo) TCI module on the right there inside my "oil tank" I'm running a 3 position w/momentary key switch so no need for a starter button. the only things not in my "oil tank" are the reg/rec witch are mounted on the inside side of my battery box for cooling.View attachment 205048View attachment 205049
People will pay good money on ebay for some of the stuff you might be throwing away, plus get to extend life of their bikes. Chopped bikes is the source of a lot of parts there I think.I threw away nearly all the electrics/wiring on mine as I am chopping it.
Correct, that’s why I have a panel mount glass buss fuse holder mounted as well.If you plan on using one of the fuses in the fuse box as the main, you can't use a fuse box like Rustie linked to. It only has one power feed in for all the fuses. You need one like this, with separate power feeds for all the fuses .....
https://www.ebay.com/itm/393602515110?_trkparms=amclksrc=ITM&aid=1110006&algo=HOMESPLICE.SIM&ao=1&asc=236212&meid=744f9683b2db4f99b5319f3c9fa4f0e1&pid=101195&rk=1&rkt=12&sd=392729613980&itm=393602515110&pmt=1&noa=0&pg=2047675&algv=SimplAMLv9PairwiseWebMskuAspectsV202110NoVariantSeed&_trksid=p2047675.c101195.m1851&amdata=cksum:393602515110744f9683b2db4f99b5319f3c9fa4f0e1|enc:AQAGAAACEDWRDF1POPZVO6uWbAgMua2nuWHhxAoABSiMUDBl9sXuFeqB3hUP3v0rbJGH7wW2eKHySfHaD1UomGAHRbyVkmornk0h7MZm1hE9sMsEyRU7uMOxWD6YN%2B1OByn8WYxcRcafT0LKwnXfJK2LwRrvJ7SDID5MzLssRWuMN8unZzpDW74hOZd1jsAVA74SdaO2Zxg3WX1M5QxJNL1YLWskT%2Fy%2F1P1OqetvYOCPRt8mxhtLCD0JjeJjWvgQhnn4PDTAp9j5qrAEDLbPhX7KPM4ghyvwqIrg5ezR8EtAO1aS6JMAyVh3lncfQ4Hv2Tnqwk4f%2Bl8xRQ6o7DCAV%2FNBfbrf90tvHuWjv5J6MHvIq20q3pbofx3AZWxAmT0HVpScpfamo1yBqKcJgvZ5k%2F8EpFjofkAS5WCbZ8QWK%2FyWHzpTnBmScAek9KPvhWHalmlOraJwkA%2FcJZEynUZa6LEzQatgTSjaJHYfzvCIVsvBq3GrcBMMC%2BYwxt1ydpZRIS8OvRyhLpce2AwWegaknXnlloFKZIPFGldM2sigfmeiyXmcKVGTZ%2FxdRNjpivXG5q54ektwibMBNBq7bM7ACSX8J1Bs2Dr30X0hf2bv6FREZsAmeSdn4%2BLAcuTiWQodAR7tPm%2F%2Bfa4L32hvuyQJEitxWaNWMaPPd9K0C%2BPSILPjDN7nhdA%2Fk7wXWQBXghMbDjt6BEhyrg%3D%3D|ampidL_CLK|clp:2047675&epid=5039133645
I noticed that. I’ll have a big fat 30amp fuse separate as the main.If you plan on using one of the fuses in the fuse box as the main, you can't use a fuse box like Rustie linked to. It only has one power feed in for all the fuses. You need one like this, with separate power feeds for all the fuses .....
