ANLAF
XS650 Guru
Fellers,
Everything, as best as I can do, is properly set-up - can chain perfect, gaps to spec (checked and rechecked) the timing (Boyer) is spot on, floats set to 27mm (BS38s), jets 137.5 and 30, screw 2 full turns out, plugs light brown.
When running the engine is purring really well. I am currently on capacitor (waiting for a new battery).
Here's the thing: it is not starting first/second time as it did (even with capacitor) since I overhauled this week, and when I cut the engine, even from idle, it stops then a pop form each cylinder in turn in quick succession.
In my limited knowledge I suspect one (or a combination) of two things:
1. the timing is slightly retarded; or
2. the mixture is a touch lean.
Any ideas, fellers?
ANLAF
Any ideas, fellers?
ANLAF
