Alright gentleman, and ladies if they're there, I have a question for you all.
Last night I looked at how I had my rear fender mounted to my bike. It's currently mounted to the swing arm with minimal clearance to the tire. Was a little concerned about this and the vibes of road travel shaking the fiberglass apart so I toyed with the idea of mounting the fender to the frame.
If it's hard mounted to the frame I need to make sure there is enough tire clearance for travel. I busted out the old Trig book and used the law of Cosines to figure to total up/down travel if the shocks did a FULL compression. Turns out if I did my math correct a full compression of 2.5" on the 11.5" MikesXS shocks would result in a 4" vertical travel of the rear tire. This could be a problem. My fender can only make a max clearance of 2.5"
Would this be a problem? Or if my shocks did a full compression would I be in a whole world of hurt and the fender and tire are the least of my worries?
First picture attached is how the fender is mounted but with the stock shocks. Second picture is a photo of the new cheapo shocks from Mikes.
