Doug79
OK I give, how does the black trim ring come off the face of the tach and spedo? Ive tried unscrewing them, that didn't work and swearing at them didn't seem to do much good either.
If you mean the ring that holds the glass on the gauges, it doesn't or at least was not designed to be removed.OK I give, how does the black trim ring come off the face of the tach and spedo? Ive tried unscrewing them, that didn't work and swearing at them didn't seem to do much good either.
Hi Doug,I wonder what kind, if any, options I would have to replace them. Maybe somebody has done that. I really don't want a used set. I already have those.
They do come up on Ebay as NOS, but you don't want to pay the price. Last one I saw was over $500.
Patience, yes, but not too bad. I got that ring off whole, put the face back together, and crimped the ring back on in an afternoon.If you mean the ring that holds the glass on the gauges, it doesn't or at least was not designed to be removed.
That being said they can be removed with lots of patience and careful use of a small screwdriver. From the back side you can carefully pry up on the crimped over part a little at a time working around the gauge. Then once you are done doing what ever you wanted it off to do you have to carefully recrimp the ring back in place. There are other methods but that is the way I did one of my own years ago.
Try doing a Google search on "Open speedometer of motorcycle" or something of that nature, never know what you might find!
I like the method of using a lathe, but only problem, I don't have a lathe
My faces weathered and curled both gauges appear to work fine so this is a cosmetic, but necessary, repair..where should I look for replacement gauge faces?
