Chuck
Useful idiot
I have a 1980 XS650 Special. The tachometer reads too high of an RPM. At lower rpm, 2000-2500 RPM, its about 200 RPM too fast. At higher RPM, 4250, it reads about 500 RPM too fast. Does anyone else have the same problem?
Chuck, I run 16" rear 17-34 sprockets & I get the same rpm as you, 4800 @ 60 & every thing seems correct, maybe pamco's (hush) is off?
The Speedo and tach will read slow when there is damage to the magnet drive inside or if it has been sitting, they somtimes free up with use.
What is the history of the gauge. Did this happen overnight, is this a new aquisition, has the po taken the gauge apart. You will see damage to the bezel if the gauge has been dismantled
Need to know the answers to be able to help you more
It does sound like yours is off. Here's a page you can enter your own numbers for wheel size, gearing, etc. It shows about 62 @ 4200 with your wheel/gearing .....
http://www.gearingcommander.com/
