in inches .003" and .006"
XS650 motors relentlessly hammer their tappet ends and valve stems...
I don't see nothing wrong.....
I have to confess I've not tried these settings myself yetWut the peanut gallery sez...... If you can stand the clatter.
P.S. .003" is the intake, exhaust is .006"
Noon; switching to coke.
...yamaha recommended much looser settings for their earlier models XS-1 and XS2 . Inlet 0.006" and Exhaust 0.12"
I read that Yamaha recommended tighter settings for later bikes to reduce tappet noise .
A well known X650 Engineer Howard of Smedspeed recommends much looser valve settings and gives a very instructive explanation which he has extracted from some pretty exhaustive testing . Howard recommends 0.006" Inlet and 0.12" Exhaust...
...I have to confess I've not tried these settings myself yet
Apologies for the metric measurements but to be fair the whole bike was constructed with metric dims
I think they call it a senior moment .There's that missing zero again. Weak tea???
Interesting read on the wider clearances, I have been running mine at 0.1mm and 0.15mm for years as that is what Halco recommended...... !
yes the shim that frequently gets left out at clutch rebuild time is the 1mm thick large shim ( shim 5 in my image) that is placed against the needle race . its due to the fact that Yamaha workshop manuals left the washer out of their drawings and countless owners have also been leaving it out over the decades.Yes I am brit, er your clutch, in my engine there is a thin shim on to the bearing then a plate then the outer basket then the baring plate and then the roller bearing then another plate then the inner basket and finally a flat washer a belled spring washer and the nut.... I have just checked the manual and my memory is correct.... is a lot of shims and plates in there.... I think I had to check the exploded diagram one time to make sure as it confused me the number of bits and the order etc. just saying that extra shim might be correct....
