This has been very interesting, I have had a read of Howards page as well. I am definitely gonna try loose that is all making good sense to me. I have to confess when I was working in the bike shop doing the SV1000 the guy running the place was explaining to me that on shim motors there is less component wear and the clearances close up over time as the valves beats into the head, my thinking was tight clearances = quiet engine but he insisted that big clearances were better as longer service intervals, I had never even considered the concept we have been discussing regarding the lift ramps and that period of time the valve isn't shut properly or open much and just loosing compression...
Good pic on the clutch, glad it was an extra washer and your not leaving bits out.... I think the pic in the manual is not showing the bearing plate as it is part of the bearing, confusing though if you are looking at it for the first time..... I was having quite a few issues with the clutch so did double and triple check the order was right, its still a bit grabby but its the nicest its ever been, short of replacing every component lol....
