finishing up the top end work on my related '83 GR650 (cousin to XS) with shim and bucket valve adjusters.
anyone have experience as to the thickness of the case hard layer on bike shims in general, or whether they are through hardened? after the valve work, i'm considering "lapping" .0005"- .001" off the underside of 3 shims with 400 grit paper taped to my granite surface plate. have seen conflicting opinions on trying this but they are originally manufactured on a surface grinder one assumes.
the valve spec is .001"- to .003" clearance. i don't have a .001 feeler gauge and .002 is a no go. buckets can be rotated when cams are at adjustment position but there is some drag, so i'm guessing clearance is under .001".
