I bought an XS-2 a couple months ago and after getting it running decided to replace the fork seals. The guy I bought the bike from said that the guy he bought it from thought it had XS850 forks on it. I don't believe that is the case as the caliper brackets are on the leading edge of the forks I have. They also have the ear cast onto the lower tubes to hold the brake line clip above where the ears for the front fender are. The cap on the upper tubes takes a 17mm allen to take them off.
They sound exactly like 74-76 XS650 forks, except they are 36mm tubes. The seals I pulled out were 36mmx48mmx10.5mm and looking through the bikes that seal size is supposed to fit nothing looks anywhere close to what I have. Was it a common thing at any to machine the lower fork tubes out to fit larger upper tubes? I've spent the last week looking since the 34mm seals I assumed I needed obviously won't fit and haven't found anything that looks right.
Any ideas would be appreciated. I haven't taken any close up pictures of the lower fork tube, but if anyone thinks that it'll help it's easily done.
