XS-2 Battery
Major Domo
Athens, GA
The battery on my XS-2 is deader than a door nail (won't hold a charge). Looking for a reasonably-priced AGM replacement. I usually by Yuasa, but as I may be selling the bike, I don't think I want to pay so much for a Yuasa. So what are other's using? Thanks!
NAPA. There’s is made by Deka. I’m not sure if they cover XS-2. My later XS650s are running them.
I bought 1 of these last year for a XS2. So far it's working well.
https://www.ebay.com/itm/202668222500
+1 on the Mighty Max. I’ve bought three for three different bikes and couldn’t be happier. Amazon is a good source as well.
Furthermore, the KMG YT12C battery has the terminal polarities on the correct sides.
The Mighty Max, which I linked to above, and the eBay battery cited above, have the terminal polarities reversed from what is proper for a 72-73.
I somehow left the key on and discharged the battery to a point the charger thinks the battery is bad and wouldn’t charge it. I used the series trick to fool the charger. I connected a charged battery in series. Pos-pos, neg/neg and connected the charger to the good battery to fool it. Worked like a charm. After about an hour the charger showed 13.2 so I unplugged everything and hooked up the charger to the dead battery. Success! Battery had enough to take a charge and this morning reads a full 13.2.IMG_6541.jpeg
All 4 of the Mighty Max batteries I’ve purchased kicked the bucket within a year.
4 different bikes.
I’ve been using a couple for several years with no issues. Maybe you got the west coast batch…..
4 different bikes.
I've only bought one Mighty Max. I've had it for 11 months. Maybe it's going to kick the bucket after one more month?
The KMG I've had for a little over two years, still good.
The OP wanted a reasonably-priced AGM. If you want longevity, go with lithium. I've got two good Shorai batteries that are over 10 years old.
In all honesty, I think it’s got something to do with living by the coast and then having a big temp shift everyday.
I knew they were low quality when I got em but figured they would last more than a year.
Once they died, getting them to recharge was a chore, and they wouldn’t hold that charge for very long. Each time dying/charging they held a charge less and less until nothing.
