After a lot of distraction from non motorcycle building... I am nearing the tail end of the wiring. Here is a quick write up on my Pamco install, with the e-advancer. "Ultimate Pamco Electronic Ignition with E-Advancer/Ignition Coil Kit" SKU: 14-0907 from MikesXS. The instructions for installing the Pamco unit are very good from
@pamcopete , so I will spare that step by step. Where I did find myself in need of help was getting everything straight with the e-advance unit. For that, I'd like to thank everyone that has contributed to the Pamco threads in the Tech section, as well as those who've weighed in on my questions within this thread, and pm's. You know who you are!
Mailman and RG both pointed me towards the attached mini diagram, for the e-advance wiring.
- The Red/White from the harness is connected to the 7.5a mini fuse lead, which wraps around the battery area, and then heads back towards the coil in a big "U".
- 3 wires from the e-advance connect as follows:
Red > shared connection to the coil (Blue), with the other end of the fuse lead.
Green > connects to coil (Black/white)
Black > Ground to frame
- From the coil, I had 2 leads. A Blue, and a Black/white. From what I could gather through the threads here, there is no polarity of the coil leads, so it was luck of the draw that the Blue met the e-advance and fuse red wires, and the B/W met the green from the e-advance.
So that's it! Again, thanks to everyone for their insights. Let's hope the 'plumbing' is sound. Getting close to the point where I'll be able to find out...
