jmink427, It's paying you back for chopping up a great looking origional 75B
Your probably right!
Update.
My rotor is definitely toast. It doesn't have any resistance because well its cracked and worthless.
The bad connection in the headlight is causing a drop in voltage from the key switch to the positive brush with the key on. What comes before the key switch? The wires seem to disappear into the handle bars looking as thought they head to the kill switch. The other side looks like it goes back under the gas tank but after that I loose track.
The mysterious draw on the battery even when bike is turned off is still puzzling me. Could a severely brunt and stripped wire cause a battery to slowly loose charge while connected without the key on?
Posted via Mobile
Hello everyone, chasing my tail here lol. XSLEO thanks for all the help! I have a better picture of my rectifier. I think it may in fact be a rec/reg.
I also have a wire that is just cut off not connected to anything but when I meter it there is a full battery current coming through.
Posted via Mobile
First let me say thanks to XsLeo and RetiredGentleman for your expertise on these issues. I will be changing the wiring around tomorrow and have already unhooked the regulator.
If I understand correctly I will not need the nylon screws because of the type of rec/reg I have. Is this accurate?
If so all I need to do is
1)install new stator
2)install new key switch
3)hook reg/rec up correctly and get a new rotor
and I should be charging and riding?
can you think of anything I may have missed?
Also I had a front brake that was siezed up and now the piston wont come out of the caliper
So far I've used compressed air, a grease gun, and even put some volitile mixture inside and tried to blow it out lol. Its just so rusted in there its almost like the piston is part of the caliper now.
I guess I should stick to one problem at a time but I have the replacement brake pads and rebuild kit ready to go just have to get this caliper out and hopefully salvage it if possible.
Posted via Mobile
