Quote back about 20 posts ago.
"As a general rule no returns on electrical items. Sadly there is a very good reason for this rule. Replacing parts to find the fault often results in more ruined parts. Just sayin....
You might try a craigslist ad for charging system help. We can only do so much from a distance. I get kind of frustrated on these threads. You are doing well (much better than most) trying to help us help you. But, straight up, an experienced electrical guy, hands on your bike, would have this hammered out in about 10 minutes."
One picture would have solved this 2 weeks ago. Thanks for telling us where the problem was. Fessing up must have been hard.
Confession I am having fun with a 77 right now. It works perfect, then out on the road after 20 minutes it blew it's fuse. No tools or spare fuse, I stuck the holders together and got home. I have the led on the bike. showing low charge at idle then "after a while I saw high voltage, green red flashes, then very low voltage. all the way down to VERY dim lights, Then back to running, charging perfect. Replaced original fuse with auto reset circuit breaker. Popped the breaker, it reset and went back to running fine, rode it home. Last night I rechecked rotor, (previously replaced with used rotor), 5.8 ohms, brushes, good length, battery is new,lead acid, battery voltage, even after funky charging is high, cranks great, lights are bright. Replaced ground strap from battery to frame with new, cleaned strap mount. checked hot strap from battery to solenoid, opened rectifier plug, checked diodes, all good. greased, replaced plug. Opened regulator, sanded, cleaned points (regulator was very clean inside) Rechecked recent work in headlight (including rerouting wiring to the newly installed LED voltage indicator) and under gas tank mount of new coil Pamco install for possible shorts, nothing found, Removed reserve lighting unit which had been a bit flaky, jumpered wires. Temporarily added a digital voltage gauge for closer voltage monitoring. Will test ride again today. Wiring is bone stock except changes mentioned above. Bike was in generally good to very good condition, dry stored and has been recently brought back to life.
