Without me reading back through....
What happened when you grounded the green wire?
I only tried the red and black. I can ground the green with the black probe and test the white wires. Give me one sec.Without me reading back through....
This means I will have to remove the entire housing , I removed the outer plate and I could not get those tweezers in. Is there a simpler way to get two of those bolts without removing the entire housing. I will have to also remove the gear shift lever
You can ground it anywhere there's metal... doesn't have to be the screw holding the stator.... anywhere on the stator's fine.This means I will have to remove the entire housing , I removed the outer plate and I could not get those tweezers in. Is there a simpler way to get two of those bolts without removing the entire housing. I will have to also remove the gear shift lever
*Can I not use the screw on the top part of the stator instead of the side one ?
Will get it done in the next hour. I am one man so I have to figure a way to tape the multimeter probes, hang my multimeter and then I'll be able to hold the pliers and the rev bike with the other.Did you already check the resistance between the 2 copper slip rings on your stator? I know you did the slap test, but it's worth getting an actual number, just to be sure.
I find the fuse removal optional, but the book does say that, so you can remove the headlight fuse, but leave the turn signal fuse in-place: (depending on how the harness is wired that fuse is needed to power the brushes)Can I do these tests removing the fuse for the head and turn signals. Appears the middle two are the ones pertaining to them ?
Sounds reasonable to me. Continue the testing to identify possible excess draw on the signal circuitAll, I've got some big positive news. I removed those two fuses in the middle and it has made a sea of difference. Because I had a feel the work around the turn signal wiring is a little douchy.
1. Turn the ignition on , the battery does not suck as bad.
2. Rev'd the engine and it now goes upto 13.6 and 13.7 still not 14 but the battery at idle stays at 13.00 and even climbs slowly.
3.Did the green button test with pliers and yes Voltage goes up to 15 and 16. - Note with the light Fuses on , it would not go beyond 13.
Maybe the regulator is a problem so is the wiring of those turn signals. Thoughts....
I am not sure if I will get a 14 .5 on revving if I pop back at least one of the fuses.
YES !!! . Thats what he's done. . The brown powers the NEUTRAL led.Are the turn signals powered through the headlight fuse (red/yellow wire), rather than signal fuse(brown wire)?
So If I remove this troubled fuse. I don't get Head Light and Turn signals. Having them on the battery loses power continuously on idle and ignition on. Having this fuse revving I can get max to 13 . Without them it goes upto 13.6What are charge readings @ battery with headlight fuse removed and signal fuse in-place?
