Hey all,
My xs650 engine was running pretty close to perfect when i pulled it out of my bike to change my frame. This was over a year ago.
Since then the engine has unfortunately been sitting in a wet garage with no oil in it since i drained it to remove the engine from the frame. All holes were plugged up with rags but must of gotten wet.
I had a frame built for the engine last night so i can start work on it while i get some other frame things welded.
We peeped into the exhaust and inlet ports and as you can see from the pictures there is some rust on the valves.
The right bank valves were left slightly open and i am worried the rust goes further than the head.
I have a feeling i will be pulling this engine apart to fix the problem?
My aim is to fix the rust issues and make everything safe and ready for it to fire up again and paint the engine and its bits while i have a stand made up for it.
My questions to you guys are:
What do i need to do before running this engine again?
What do i need to look out for in regards to rust and damage etc?
what could i have done to avoid all this?
Thanks
Jai
Thanks
Jai
