this thread is better than a TV detective drama lol
I guess if the extra washer and /or the dissassembly /reassembly has reduced the rotational friction somewhere on your crank/clutch then yes it would feel easier to turn the engine over.
the only other reason I could think of for easier engine turnover is if you had changed your timing in any way ?
Regarding the rubbing noise.... I'm beginning to wonder if the rubbing is only occurring during high engine load because a bearing or a thrust washer has gone somewhere in the transmission.?
The heavier load is obviously causing something in the transmission to move out of normal rotational alignment.
Have you checked to see if there is any crankshaft float ?
