Is it my turn? Anything to do with lathes, mills and other shop tools
Exactly!
Compound still moving a little, tho not nearly as bad. Needed to broach an internal keyway in a sleeve, don't have a broach.
There's a trick using a parting tool and a lathe. Mount the parting tool sideways, mount the piece in the chuck. With the lathe OFF and the back gear in to lock the spindle in position, use the saddle to drive the cutoff tool through the piece and advance it a couple of thousands after each pass.
Slow...Very, VERY slow...but it works.
It also spurred me to crack open the toy fund and buy a basic set of broaches...
Hi Downeaster,
like Beags was too polite to say:- "Congratulations! You have invented the shaping machine!"
OR
Mr. Bodger sez:-
Make two concentric sleeves on your lathe.
Hacksaw a groove through the inner sleeve.
Press the sleeves together & plugweld.
You can still fit a car in the garage? I'm impressed, my 2 car garage has never had a car in it since I bought the house.
24 x 48 garage. I can fit two (compact...a Corolla and a Yaris) cars in there. As long as no one opens the door on both cars simultaneously...
JimD54 made a comment a while back about "hanging a bolt in mid-air and building an airplane around it."
Well, I'm doing that with a snowblower...
Daughter had an 8/28 Crapsman with a 110v electric start Briggs and Scrapiron on it that I got on a horse trade with a sheared flywheel. Fixed that and she ran it for a couple of years but apparently the flywheel flopping around before I fixed it took out a crank seal and it leaked all the oil out and seized up.
I gave her my MTD e-start and took this one back. No future at all in rebuilding that POS Briggs with it's aluminum cylinder and no rod bearings. So I grabbed a Horror Fright Predator. Figured if I was gonna hafta retrofit things, I might as well go with MORE POWER! so I bought a 13 horse 12v e-start. Had to set the motor back a bit over an inch to get the pulleys to line up plus it has a larger mounting bolt pattern, so had to build a custom mount for it. In order to drill the holes to bolt the new motor mount to the chassis, it was easier to strip the chassis down to the frame and drill it on my press.
With the motor mounted to the chassis, reassembling the transmission was easier with the motor/chassis assembly hanging at shoulder height.
It's hanging from my Horror Fright 800# electric hoist that runs on barn door track the length of my "mechanical bay". It's been handier than a pocket on a shirt, especially since at my age I'm much more likely to sign a check than resort to brute strength and ignorance like I did 30 years ago...
Today's project, this one's been on the list for a while...
Since I've got to turn some new acme screws for horizontal project figured I needed a way to get good, accurate angles for an acme threading tool. Got 0, 10 & 20deg for general turning tools, 45deg for chamfering, 14.5 & 30 for threading tools. We'll see if it works out.
Mostly I use HSS, a few carbides, rough 'em out on the belt sander & clean 'em up on the diamond wheel. $2 ea. for those small wheels ya got there- can't go wrong at that price.
That looks almost home built. I'd be concerned with the spindle taper, if you can't get tool holders for it then you can't do much with it.
Machine shop pics today.
"Motion Controller Encoder" motor couplings is what I've been making for awhile now. A variety of these very small precise components.
40+ hrs a week in these very tight work spaces. This is not really a topic to discuss at a Christmas party or at dinner, So just maybe a few of you all would enjoy this typical mornings work of tool replacement.
Both the usual insert and the very small .035" 3 fluted endmill which spins at 60,000 rpm. We don't use the electric motors max rpm of 80,000 !
Anyway, here are some pics :)
